Author Topic: Intalacion de Taillights Europeas para MK5  (Read 868 times)
Offline Dubmax Tj
    • West Side Mexico Cartel Tijuana
« on: July 04, 2012, 04:21:51 PM »
Asi de  facil es  esto para  quienes  quieran  hacerlo
Offline Dubmax Tj
Re: Intalacion de Taillights Europeas para MK5
« Reply #1 on: July 04, 2012, 04:22:52 PM »
Coding (from the AMBER DIY)
Generic AMBER Coding, Central Electronics Controller, BYTES 09 through 13
U.S Code in HEX:
14 00 00 00 14
AMBER Code in HEX:
0A 00 00 0F 00
HEX 0A = 0000 1010 binary
HEX 0F = 0000 1111 binary
Refinements:
BYTE 18, BIT 1 set to = "0" (uncheck the BIT in the Long Code Helper)
BYTE 18, BIT 5 set to = "0"
BYTE 19, BIT(s) 2 & 3 set to = "0"
Rear Fog?
BYTE 03, BIT(s) 1 & 2 set to = "1" (check the BITs in the long Code Helper)
BYTE 18, BIT 3 set to = "1"
BYTE 04, BIT 6 set to = "0"
Bonus BYTE/BIT:
BYTE 17, BIT 0 set to = "1" (emergency braking, flash the Tail Lights)
BYTE(s) 18/19 contain BITs relating to Cold Diagnostics that are not required on the LED Tails, except BIT 3 which is the BIT for the Rear Fog Diag.
If you are not doing the Rear Fog, then skip what I posted concerning the Rear Fog.
PDF for Amber Tails appears to be offline.
Wiring is as follows:
Left Tail Light, Pin 4 Black/Red
Left Tail Light, Pin 3 Black/White
Left Tail Light, Pin 2 Gray/Black
Left Tail Light, PIN 1 Orange (or Brown) Common Return Path
Right Tail Light, Pin 4 Black/Violet
Right Tail Light, Pin 3 Black/Green
Right Tail Light, Pin 2 Gray/Red
Right Tail Light, Pin 1 Orange (or Brown) Common Return Path
Offline EdgarVR6
  • Newbie
  • VW
« Reply #2 on: May 06, 2013, 05:48:36 PM »
sta chido el how to... muy explicito, pero a mi la verdad se me hace que esas calaveras se ven muy feas, muy tunnings, pero psss muy especifico, buen aporte  :D
VRSICK <3
CHIHUAS :D
